google:1 reduction gear set
  • google:1 reduction gear set
    I had no idea Lego has building blocks like this:
    https://www.youtube.com/watch?v=QwXK...ature=youtu.be.
    You probably know that a googol, if written out, is "1" followed by a hundred zeroes. A googol is vastly larger than the number of elementary particles in the universe.
    If you could load this gearing for zero backlash, this might have use in a physics experiment involving light (or gravity waves ). Shifting a mirror by a zeptometer would be duck soup.
    Allan Ostling
    Phoenix, Arizona
    google is a search engine/advertising company.... a googol is 1 with 100 zeros. Are you making using belt reductions or planetary gears? It'd be a lot of 3d printing
      this is close enough approximation to infinity:1 gearing.
      You can use all the energy in the universe to spin that small gear and the final shaft haven't made single turn yet!
        Arthur Ganson I believe started this all with his "Machine in concrete"
        This machine was inspired by dreaming about gear ratios and considering the unexpected implications of exponential powers.Each worm/worm gear pair reduces th...
          Where was that when I was a kid? I would have been all over that- mixing it with the mechano set.
            Thanks for the correction. I wish I could change the misspelled title.
            Allan Ostling
            Phoenix, Arizona
              That is easy and no gears needed. Just disconnect the output shaft
              Helder Ferreira
              Setubal, Portugal
                Another example...
                Regards, Marv
                  Well my opinion of Lego is raised a couple of notches, I would rather see a system of gearing in steel or brass with steel frame/parts as Meccano. Plastic is OK I guess but snap together parts? I guess I am just a retro Meccano fan.
                    That's pretty slick. I could actually see a fair number of the components used having application in the home shop!
                    Lego has come a long way since it was new when I was a kid and was mostly just for building little model buildings.
                    Chilliwack BC, Canada
                      Lego Technic has gears, motors, roller chains, tank treads, differentials, pneumatic pumps, cylinders, linear actuators, etc. I've been 3d Printing lego gears fairly recently if you followed any of my posts.
