Forming an Eccentric Head on a Capscrew
  • #16
    I was speaking of the responses. The soldering/brazing arguments crop up every so often. I guess we need more plumbers here. Eccentric turning is not new either.
    • #17
      That's right. And every time it's due to the confusion caused by the ambiguous terms!
      Lynn (Huntsville, AL)
      • #18
        Yes you can, I wonder though if used the mandrel for doing multiples and maintaining timing between the thread and eccentric?
        If you left the capscrew head full size and just pressed on a round that was bored eccentrically, you would accomplish the same result and the straight knurl would hold the two together.
        • #19
          What was the purpose of making an eccentric head?? Some adjustment thing?
          JL................
          • #20
            JL................
            Part of a homebrew MiteeBite clamp: https://www.miteebite.com/products/fixture-clamps/
            • #21
              OK, that makes sense.
              Every SHCS, FHCS and every other screw I've ever seen all have heads that are eccentric, but not by that much.
              I have a #4-40 FHCS that I'm trying to get the head concentric. Just the opposite of what the OP is trying to do.
              JL........................
