My office, where I presently sit, is off of my den where my wife spends most of her time. And she likes it COLD. Even in winter, she has to run the air conditioner. I think it is an inherited thing. And don't even suggest anything, she stays.
The central style heat/AC is common to both rooms so there is always cold air coming my way. I can shut the vent in winter and use an electric heater which is sufficient for the south Texas winters. But summer is a problem as I need at least a bit of cooling. So I try to adjust the ceiling register to admit only a small amount of the cool air. But since it is a typical, low cost vent, it is difficult to get a good adjustment. The fact that it is on the ceiling and can not be reached directly without a ladder only makes it even more difficult. I use a length of copper pipe to tap on the lever to make adjustments but this is hardly an optimum solution.
What I am wondering is are there any registers that are of better quality so the adjustments are smoother and more precise? And are there any that are remote controlled? I have searched a bit, but they all look very similar and none seem to offer a way to control them without getting on a ladder. I would prefer to do it from my desk chair. I haven't measured it, but it appears to be around 5" X 10" or 6" X 12".
Any suggestions would be appreciated.
