Annealing Dowel Pins
  • Annealing Dowel Pins
    Can dowel pins be annealed, need some soft 1/16 x 1/2 inch pins to hold a part in place, bought 500 dowel pins off the "Bay' for less than I can make them for, would really like them un-hardened. Box states "Alloy steel' unsure of which alloy though.
    Thinking 1400 deg F for an hour. Thoughts/recommendations
    Mike Hunter
    www.mikehunterrestorations.com
    they don't need a very long time at all at soak, but the key a slow cool. I welded up a box and have it filled with ash from the fireplace, works perfectly. You will however get scale..... various ways to avoid that. Is making them still look so bad?
      Expect some scale on the surface.
        Thanks for all the replys
        Well I do color case hardening and annealing here in the shop, fairly familiar with keeping oxygen away from steel parts, Plus a quick tumble in citric acid and they come out bright and shiny.
        Plus, 500 dowel pins ran me $11 that includes shipping, No way I can make them for that price
        Mike Hunter
          I buy 1/16" steel welding rod for use as unhardened pins. It is cheap and readily available.
          Design engineer
          Barrie, Ontario, Canada
            Heck if you seal them up in a metal container along with a wad of paper you won't even get any scale.
              Nothing works better for slow cooling than ag lime. Cover parts with an ample layer of lime and they'll take
              a long time to cool...
              Keith
              __________________________
                Why can't they be hard, are they shear pins ?
                  Do you need fully annealed, or just soft enough to work on? If its the second, a soak at 550-600f should be sufficient for most alloys. Should bring most alloys down to 45-50rhc, still pretty tough but workable, mostly. Going up to bout 1000f, if you have the capability, should drop you down to 35-40rhc, pretty well machinable, thats what 4140ph is sold at after all. The relatively lower temperatures will be less likely to cause distortion or scale than a complete anneal
