DP "Mill Cap"?
  • #16
    Originally posted by john hobdeclipe View Post
    ...A retaining ring would need to have a significantly smaller diameter...
    On the Arboga drills they use a slotted washer that fits inside the "cap" or nut. You slide it on to the tool and tighten
    the nut to lock it in place. If you didn't have a slot the only way the washer would work was it it was captive to the tool.
    The slot allows it to be removed. I think they make washers with different size slots to accomadate different tools...
    Keith
    __________________________
