Pulley repair
  • #46
    Originally posted by 754 View Post
    to all those guys that say just cut that flange off, when a sparkplug or cylinder goes in your vehicle , do you just leave it that way because you only travel at 60 percent of top speed ?
    Just because your car can go 100 MPH means you should go 100 MPH everywhere
    • #47
      U
      Well it would depend on what I used that vehicle for. If I only used it around the farm, the answer might be yes. If the OP is only using it for projects in his home shop he will probably never need the fourth belt. I have the opposite situation on my horizontal mill. The motor has a triple sheeve but the previous owner replaced the driven sheeve with a double. I've never pushed it hard enough for it to be an issue.
      BTW nice repair.
      Tom - Spotsylvania, VA
