I have a thread going on about a question regarding using a lathe to sharpen drill bits. I wasn't sure if I should put this in that thread or start a new one. If the mods feel that starting a new thread is bad form I'll happily combine this in that thread.
I recently discovered a fixture for my KO LEE T&C grinder that, I think, will be adaptable for grinding drill bits. I also remembered that I had this collet holder and collets. It's an MT taper and the fixture is a 3/4 bore so I'll make an adapter for it to fit. The part I'm adapting the collet holder to is part of a pair of centers fwiw. The "nut" on the top of the bore will index the collet holder 180* when I make the adapter and mill two grooves into it on opposing sides. Any input is greatly appreciated.
Thanks
Thanks
