...Yep, sharpen them....To sharpen, simple take a flat dollar store sharpening stone and gently press And travers it against the running wire wheel....
Totally nuts.
If you want a more aggressive cutting wire wheel,
just switch to one that has stiffer and larger wires.
They make twisted and knotted wires too.
You'd be better served buffing you knob.
You can not make precision ground stones by rubbing them against each other. Not even if you do that with three of them to generate a flat. That will only dislodge the abrasive particles, leaving the sharp edges of the lower ones sticking out. For proper precision ground stones, the abrasive particles must be ground FLAT in place, not dislodged. And the only way to do that is with a diamond wheel on a surface grinder. Those flattened abrasive particles will glide across a flat metal surface without removing anything. If the abrasive particles are only removed, the remaining ones will all have sharp points that may lay in a flat plane, but they will still cut into the metal surface and that is not desirable in a precision flat stone.
Some sources even recommend using precision flat stones on Jo blocks. You would not want to do that with stones that were flattened by rubbing them together. Those Jo blocks would never stick together again.
Paul, you misunderstand. I ground the cheap stones on my surface grinder just like my norton stones.. unlike the quality norton stones which glide across each other after grinding, the cheap stones crumbled and dragged across each other. I assumed it was due to the poor binder or processing of the stones. Hence my comments in that post.
Totally nuts.
-Doozer
A blistering opinion for something you have not tried. But hey, everybody is entitled to their own opinion. You are, but then again, so am I.
i dress my gage blocks with the angle grinder prepared by matti. i like those stones, especially the one for $1'055. whats the flatness spec on those? 1/4 wave length i heard? and they are self healing too, righ?
I tried it on a very bent-over wire wheel and I think the result was worse. What would have been blunt wire ends were now smoothed over by the stone. I may try it with the wheel backward; I have nothing to lose.
