Hi Group,
I have the 10Ton HF porta power and want to use the pump for a hydraulic floor model shop press. Can I take the pump up to 20Ton if I find the correct size cylinder? I'm looking for suggestions on the press cylinder that would work. I have built the steel frame and am in the process of finishing the table, so it's not done yet but I'm getting close. The hydraulics are still not figured out yet.
I did consider the bottle jack idea, but I'm hoping to have the type with the trolley for the cylinder to do off center presses.
I look forward to all comments and suggestions. Oh, and I'm not going to go buy one, it's about the journey as much as it is the end result.
TX
Mr fixit for the family
Chris
TX
Chris
