Dead right about the algae problem caused by the tank being translucent. Painting the outside black or keeping the tank in darkness is probably the only solution. Get two tanks while the price is right.
OT: Rinsing out 'B-Alanine' from a poly IBC container to use as rainwater reservoir?
Originally posted by old mart View PostDead right about the algae problem caused by the tank being translucent. Painting the outside black or keeping the tank in darkness is probably the only solution. Get two tanks while the price is right.Location: Jersey City NJ USA
That's probably why the also come in black: https://www.directwatertanks.co.uk/1...et-un-approved IanAll of the gear, no idea...
Originally posted by Noitoen View PostBe sure to keep it out of the sun light otherwise the UV will destroy the plastic. A good coat of paint will solve both issues.Location: Northern WI
Maybe take advantage of the frame as attach points to secure some type of wall material and a roof. Paint it up to look like a little dog house, or a doll house, or a bird house, maybe an out house?Last edited by tom_d; 06-12-2020, 02:48 PM.
Originally posted by Noitoen View PostBe sure to keep it out of the sun light otherwise the UV will destroy the plastic. A good coat of paint will solve both issues.Location: Jersey City NJ USA
Originally posted by gellfex View PostI've often wondered how much more expensive it is to make PE UV resistant... ...I think a physical covering like a tarp, or a wooden housing would be better than paint, especially to actually see if there's an algae problem.
I covered this one with cheap 6" fencing. The pickets/runners (runners are just 4x3/4" pickets) are screwed to the the cage with machine screws. The top just lifts up. On the non sunny side, I cut a 1" slot to see the water level, but it is hard to see, so I usually just flip up the top and take a look. I put a ball valve spigot in the drain cap (machined a few parts to make that work well) and the PVC out the side is the overflow. Still haven't gotten around to painting it, or the house.
Originally posted by Joel View PostSomeone near me used to sell black UV resistant ones for $100 and the regular ones for $50. By the time I needed another one, they were gone and I haven't found any locally since.
I was considering putting a float valve to the house water inside to keep the level up if it gets too low. Do you have a method, or just keep an eye on it as you say? I need to research what to do for the pump, best thing would probably be finding an immersion pump that will fit through the fill opening.Location: Jersey City NJ USA
Someone gave me a few of those blue plastic barrels a long time ago. I wanted them to catch rainwater off the roof for my garden. There was a label on them that said oakite or something like that, and Industrial cleaner or degreaser I believe. I washed them out good with soap and water several times. Unless the plastic absorbs these chemicals they should be safe for rain water for plants.
JL.....
Originally posted by gellfex View PostCool! That's the idea. There's some $20 3/8" "barnboard" patterned exterior plywood at Lowes that I was going to use for a house for my smoker, guess it would do fine for this too.
I don't do anything beyond letting the rain fill it. I modified the guttering so that this fills up first, and it takes very little rain to refill. It usually doesn't run dry until late July or so (am in TX). I did find that the cheapest strainer/sifter at walmart fits exactly in the top where it fills from.
If you can raise it a fair bit above where it is being discharged, you may not need a pump at all - although a drip irrigation might require a good bit of pressure, IDK.
