V block clamp question
  • V block clamp question
    This clamp came with a a shop made (perhaps as part of a test?) V block. I'm curious if there is a purpose for the bolt that goes through the clamp horizontally has a purpose? It has a knurled end on both ends and I can't imagine what it is for?
    Thanks Click image for larger version
    Possible locking mechanism so the vertical screw does not loosen up?
      Look like shorter clamp screws and a convenient place to store them.
      Joe
        I have always thought those were for additional support when using the block in a horizontal position. You can screw it down to touch the datum surface to hold the block level, and use the other one like a jam nut to keep it from moving. Anything of weight in the V part will make it want to tip down in that direction.
          It looks like someone tried to copy the Starrett 567 V-block clamp.
          For added support when the v-block is laid on it's side.
          JL.................
          https://www.starrett.com/metrology/product-detail/567
            Excellent! Glad to hear they have a purpose.
              I think we doubled!
              JL.......
                It is unique, the maker thought about how he would spread confusion and he succeeded.
