Lead.
  • #31
    Shield your radioactive source.
    Tom - Spotsylvania, VA
    • #32
      Originally posted by old mart View Post
      Think of an application where changing the resonant frequency of something would improve it. Perhaps a lathe or mill could do with a bit more mass in the right place.
      Im wondering about this too. I have about a ton of lead scrap here, and im in the process of converting a Seig X2 into cnc. Ive been looking at the epoxy granite, but would lead work better/worse for dampening?
      • #33
        In NJ, CLEAN LEAD $00.60, wheel weight or other dirty lead $00.06/lb.
        • #34
          Other uses - clock weights and pendulums. Model boat makers need ballast.
          If you can find some old pewter you could make some proper solder.
          All you fishermen and gun nuts should be retrieving and reusing your lead not letting it stay around the countryside as a pollutant.
          • #35
            Originally posted by LKeithR View Post
            A couple lead hammers in different sizes are always useful in a shop. A taping block--basically a chunk of round stock--is
            handy for finer work
            This.
            +1. i have the same - no marring of the work piece either.
            I also cut off strips and tape onto cranks and conrods and wheels etc when initial static balancing.
            • #36
              Um, you do know that when a fisherman loses a weight or jig it's at the bottom of the body of water, right? It's pretty much as absurd for a hunter, but there's movements in both sports to limit or eliminate lead when possible. But I can't cast jigs of tungsten, brass or steel in my shop!
              • #37
                Last I checked scrap price for lead was in $0.80 range, a google today shows it to be between $0.35 and 0.75 per pound.
                Car batteries and wheel weights at the bottom end of that range, soft lead at top.
                • #38
                  Bad lead for fishing weights has been banned in the U.K. for about 30 years ! All fishing weights are toxic free !
                  Knowledge withheld is knowledge lost
                  • #39
                    Well, this old fella is pretty generous. He asked me how much I wanted, then he said just take what you want. So now I have about 120 lbs or so- didn't change the pile much. Hold down weights would sure work for me, I'll make some of those. Lead hammer, sure. How about a lead flywheel? Something for a punching press, perhaps? Maybe I could take a piece and surround it with yellow foam and leave it on the coffee table.
                    • #40
                      Pity it wasn’t pre nuclear lead, that stuff has a hefty price tag, honest, anyway somewhat off topic but interesting, there’s a lead firm or metals firm over here I visited that made shot, in this thing called a shot tower, the lead was poured on a big Chinese hat cone and then fell down the tower, solidifying on the way
                      ancient process apparently
                      mark
                      • #41
                        Lead lick, like a salt lick, but lead, for people.
                        • #42
                          Saddle makers would buy all you could produce if you cut the lead up into smaller chunks and cover the chunks with either leather or canvas. They use them to weight down the leather parts of western saddles while they carve them. They never have enough.
                          • #43
                            mark
                            IIRC pre nuclear era lead is not that special yet but Roman Empire era lead has had some special uses:
                            https://www.nature.com/articles/news.2010.186
                            I can't remember exact details but time after smelting is the important property in this case as some radioactive elements are removed in the smelting and some others remain in the lead.
