Shelf and In Use Life of Rust Preventive Paper
  • #16
    Well, yes it is, but garage doors open and even when closed they don't seal very well. I do not know what the relative humidity is, but I guess I should buy a gauge. I had one once, but I don't know where it is now.
    Originally posted by reggie_obe View Post
    I thought your garage shop is climate controlled? What is the relative humidity in there?
    • #17
      I believe I purchased it on the internet somewhere but I can't remember where. And the record of the order escapes me at the moment.
      McMaster does sell it:
      https://www.mcmaster.com/vci-(volati...hibitor)-paper
      Originally posted by loose nut View Post
      Paul where does one purchase this womder paper. I have used camphor blocks in the past but they are available around here any more.
      • #18
        You can buy it direct from the company. I think MSC also sells it.
        JL................
        • #19
          Brownells, a gunsmithing supply co in Iowa also sells the paper.
          • #20
            I've been happy with Zerust. I get some of the thicker plastic packaging and cut it up into pieces that fit the need.
            No affiliation just a satisfied customer.
            Greg
            Greg
            From Central Arkansas
            • #21
              Amazon had 1000 sheets of 9" by 9" paper for 44$, cheaper than 1000 sheets of 6" by 6 paper.. Which makes no sense to me.
              I couldnt find a more reasonable deal anywhere else. Mcmaster has a 2700 square foot roll for 90$ maybe 130 after shipping.
              Or pay 8 cents a sheet for much lower quantities..
