Dura-Bar vs Versa-Bar
  • Dura-Bar vs Versa-Bar
    I am actually doing research for a job interview with Dura-Bar and trying to get a little input from those more knowledgeable than me on what might be the core differences between these two companies. It appears for continuous cast-iron, Dura-Bar has 80% plus of the market share but what are the reasons why someone would choose versa bar other than possibly just less expensive. Any thoughts on either of these two companies is greatly appreciated as I do my research.
    Dura-bar certainly has the name recognition. If the two products are at all similar, smaller/mid-size shops will likely buy on price, all else being equal. There isn't any other reason.
      Too much harassment over at Practical Machinist?
        What would you expect from "machinists"? Nobody LIKES to machine cast iron and few have a say on material. Machinists take it up the arse from management and engineers. Better to present the question(s) to an engineer site where the specifications begin. Management deals with cost and profit.
          They ran him out of town on a rail. I hope that broken piece of dura-bar didn't leave slivers.
            Originally posted by CCWKen View Post
            What would you expect from "machinists"? Nobody LIKES to machine cast iron and few have a say on material..
            Durabar machines like butter. Stunning results, and no mess. It's not your grandad's cast iron. I love it.
              I love it also. But then, I suppose I'm "nobody".
                Nice to see that we are being just a welcoming here.
                  me to, so easy to machine. I did 8 4" bushings recently, bored from solid and that for me was a lot of cast iron. It was enough quantity that the black power was a bit of pain, but boring with a .125" depth of cut and nice little chips flying made it so seem so much easier than many steels
                  As for the OP's Q, aren't they are two brands, not types of metal?
                  edit, ok,. you're not looking for machining advice. I have no insights to either company.
                    I love cast iron as long as my machine tool is completely covered so I don't have to clean up the mess later
                      Of course it's easy to machine. I've even machined barbell weights made of the worst possible waste products. What I was referring to was the clean up. If you LOVE that, you're demented.
                        I have no problem with doing the cleanup -- not because I love cleaning, I don't. I have no problem doing the cleanup, because I love my lathe. Spent a lot of money on it, too.
                          I guessing you have never machined Durabar. I use the 40ksi and 80ksi products, and it does not produce the "dust and grit" of crappy cast iron. On my mill I get perfect chips that are little curls, and similarly on my lathe. Vacs up nicely.
                          As for "messes" (cleanup), the worst in my shop is machining PVDF and/or many other plastics, and for metal... wads of aluminum chips caked on with coolant or light oils. Then there is stainless needle swarf/chips...
                            I would guess that the Versa Bar would be cheaper because it doesn't have the name recognition, and therefor maybe an easier sell to smaller shops. Especially if they'll do smaller quantities and try to make up on volume.
                              If I was going for a job interview, I would never make any mention of a competitors products.
