What size dovetail cutter for making tool holders
  • What size dovetail cutter for making tool holders
    I purchased a 1/2" dovetail cutter for making the dovetails in some holders I'm making. They are for the phase II bxa. Turns out these won't reach. What size are folks using?
    Thanks
    Just use a straight end mill and rotate the work to the correct angle.
      1 3/8" is what I used, I think, but I've slept since then.....
      Oregon, USA
        I just checked mine. A 3/4 inch 60 degree cutter is what the BXA needs. Note that on my QCTP holders the edge of the narrowest part of the dovetail (L2 in diagram) was milled off. Without that there was a possibility that the shank of the cutter would hit that lip.
        From Shars: Click image for larger version
          Thanks. Every 3/4" cutter I've looked at has a 5/8" shank and I don't have a collet that size. My mill is an ancient index model 40 that uses B&S #9. I have about 5 collets and 5/8" isn't one. I'll continue searching. Thanks
          BTW, I thought BXA and AXA were the same size holder?
            Huh?
              5/8 x 7/16" HSS, in the shaper....
              Sorry, i'll get my coat.....
Name:	june - nov 2014 133.JPG
Name:	june - nov 2014 138.JPG
Name:	june - nov 2014 143.JPG
                Originally posted by challenger View Post
                Huh?
                It's actually better than using a dovetail cutter because it creates a relief in the corner:
ID:	1883773Click image for larger version
                  Amen, brother Amen. The only way for Real machinist to go.
                  Sarge41
                    I have a 7" atlas and will probably use it for the holders. I may also use the end mill idea in the vertical mill.
                    Thanks
                      Check https://www.shars.com/3-4-60-degree-hss-dovetail-cutter for a 3/4 inch cutter with 3/8 inch shaft. HSS for $13
                      AXA and BXA are close to the same size, but not quite.
                      Using the picture above...
                      AXA:
                      • H: 0.386"
                      • L1: 1.687"
                      • L2: 1.382"
                      BXA
                      • H: 0.417"
                      • L1: 1.762"
                      • L2: 1.421"
                      Dan
                        Thanks
                        Blimey!
                        Reminds me of that scene in Pulp Fiction.
                        Hey MF, why did'nt you tell me you had the shaper....
                        Its what they were invented for.
                        Zero tool costs, and do them in a gang like mine above, as many as you can clamp down in the stroke length and be having it.
                        Then saw to length/width.
Name:	june - nov 2014 144.JPG
Name:	june - nov 2014 156.JPG
                          Blimey!
                          Who is "MF"?
                          What type of tool post do these go to?
                          I'll be needing to do the inside dovetails and will give the shaper a try on at least one. I haven't used it in years.
                          I've read that the dovetails one the holders are a very critical operation to keep accurate and I don't want to ruin a part that's nearly done.
                          In reality making one's own bxa holders is a colossal waste of time considering they cost less than 20.00 to buy. My only reason for doing these is that they will be usa made.
                            AXA:
                            • H: 0.386"
                            • L1: 1.687"
                            • L2: 1.382"
                            BXA
                            • H: 0.417"
                            • L1: 1.762"
                            • L2: 1.421"
                            Dan
                            Thanks but they are out of stock. Shars is experiencing a lot out of stock items.
                              I don't think you need relief in the female part of the dovetail as it is built in to the male part.
