CNC router table, what next? Scanner query.
  • CNC router table, what next? Scanner query.
    I spent my COVID-19 lock down period working on the final stages of my 8'x4' (more or less) CNC router table and got it working We have made a couple of roadside signs for our museum and some trivial projects what what about the next stage?
    What sort of scanner would be used to transfer a design from paper (for example) to g-code? Simple designs I can plot manually and write in Notepad, bigger designs I can draw full size on the machine table and manually copy to g-code. But what I am really looking for is how these jobs might be done in a conventional shop?
    https://www.creaform3d.com/en#gref
    Cost is very likely far more then you would like.
      Yes, quite possibly more than I might like to pay!
        What would be really fun is to add scanning to your router table. The hard mechanical parts are done - just make an adapter to hold a handheld document scanner like this:
        https://www.amazon.com/dp/B07GVCTZ63/
        and use the router software to run it over the document and get a bazillion pixels. Then it's just SMOP (Small Matter Of Programming)
          I don't know about G code generation capabilities of Inkscape software but it can "vectorize" a bitmap drawing and I can use it to cut with my laser.
          Helder Ferreira
          Setubal, Portugal
            A perfectly reasonable idea!
              I have played a little with this but it seemed there were just too many stray 'spots' to be manually removed, not to say the idea is without merits though!.
                If the Inkscape extension Noitienposted does not work for you there are plenty more
                https://inkscape.org/gallery/=extension/
                Tom C
                ... nice weather eh?
                  There are a few things I need to look at.
                    What type of designs are you thinking about doing? That will make a difference on what software you will need. What controller are you using? Not all G-code is the same. Some controllers use non standard G-code but I am sure you know all that. You have Fusion 360 for instance and then there is Vectric V carve that works well also for router work. You have lots of options. Sheetcam is a good option and won't break the bank for producing G-code for routers or plasma. You will want to scan, vectorize, scale, convert to DXF or SVG then go into a CAM program to produce the G-code. Most of it sounds more difficult than ti actually ends up being.
                      Hi, this is the most ambitious project so far!
                      John
                        I have made a router attachment for cutting sheet material, a needler for cutting foam sheet etc, a drag knife for cutting vinyl etc, attachments for handling paint pens and brushes and of course there is scope for a few more techniques!
                        There are any number of somewhat naff designs available online but what I would really like is to copy aircraft parts to be reproduced in plywood etc which fortunately are often available in full size which we can manually copy.
                        John
                          It is nearly two weeks since my little accident but I am still not safe anywhere except sitting in my chair or sleeping in bed, plenty of time for thinking though!
                          The next stage of this project is to mount a DSLR camera on my CNC machine and experiment with macro photography. It will be interesting to see if I can handle the data volumes that might be involved.
