Admit its been a year since I cut threads on my Logan, no issues set the Left and Right hand levers according to the chart. Turned out fine. Today Need to clean up threads on a 5/8 inch 11 tpi shaft. Have never cut 11 tpi on it.
From the chart set the left lever on A, right 4 holes over for 11 tpi. Its cutting a thread twice as fine 22 tpi. Never moved the stud gears, what could have changed ?
Couple things come to mind.
1 Bought the lathe 3 years ago from a guy that overhauled and painted . He was not a machinist and never ran it. Several things needed adjusting. Posable he put the gears in wrong Sequence ?
2 Is it possible moving the lever is not moving the gear ?
Never had the gear box apart, manual does not address inside the box. Any advise or comment appreciated.
Boats
Boats
