Both of my lathes came with 4 way tool posts with an indexing system. I used them as 754 did. I'd mount 3 or 4 tools and rotate as needed. The indexing was not very precise, but got the job done. But when I was doing a job, I found myself using the tool that was close to what I needed instead of changing one of the tools to the right one. For instance, I'd use the mounted 1/4 inch HSS boring bar when I should have used the 1/2 inch solid carbide due to the length of the required stickout.
That is the problem that the QCTP solved. I tend to use the right tool now. While the QCTP does not index, it does rotate and that can be used to your advantage along with a gage to align it. I use a small machinist square to set it at 90 degrees to the compound movement.
Dan
Dan
