Interesting support grinder
  • #16
    I recently bought a surface grinder spindle that the previous owner (machine shop) mounted to a turret lathe for a particular grinding operation that they did frequently - shop owner mentioned what they used it for but the answer was a bit over my head and I only cared to know that the spindle was working correctly. Maybe the commercial part the OP mentioned/showed the image from was for a similar use. Hopefully my grinder spindle image will load (I can see it in preview)
Name:	surf grinder spindle.JPG
    Metro Detroit
    • #17
      Link to auction or auctioneer?
      • #18
        I would think that the spindle speed would be an indicator of the intended use. It appears to be a direct drive from the motor shaft so I wonder what the rated RPM would be.
        • #19
          I could be wrong, but it appears to have a vernier dial on it. If so, it can be set to a fraction of a degree easily. Whatever application it was purposed for, it needed to have great accuracy in its angle adjustment. Good for tapers- whether you're grinding them, or boring them using a specialty rotating boring tool.
          Sure does seem like it would be good for regrinding morse tapers in situ.
          • #20
            Or a radial drill press.
            Any name tags or anything on it ??
            JL.....
            Thats the first thing I thought of when I saw the castings I saw big drill press.
            Very nice looking machine. JR
            • #21
              I located a new unit the same as the one I showed a picture of in the original post. The new one sells for just under 3000 Euros. It is made to mount on a grinder.
              • #22
                Auction was a couple of weeks ago, I was the winning bidder at $6 (including auction premium & sales tax)
                Metro Detroit
                • #23
                  Doesn't answer the question. Auction listing stay up for months after the auction is over.
                  Auctioneers website please?
                  • #24
                    https://rjmauctions.com, Do-rite tool was the name of the company being liquidated.
                    Metro Detroit
