I bought this Huot index several years ago. Actually I bought a couple of them probably when someone had a special on them. One I bought for my jobber length reamers and this one was supposed to be for screw machine or stub length drill bits that I planned on buying on an as need basis or several of them when someone ran a special.
So just the other day I took it out of it's original box and found out it's not the one for stub length drill bits.
Well, only way I'll be able to use it would be to add a shelf or ledge for the shorter drills to sit on.
This could be as simple as riveting a small bar of aluminum in each of the racks or even a piece of plastic cut to the proper size.
I did call the company and they said if I could find the receipt where I bought it from they would replace it but would have to go through the store.
Any thoughts??
JL.................
Any thoughts??
JL.................
