I've had this edge finder since about 2008. I've always had problems with it's accuracy. I've done several tests to prove it. Every time I would indicate the edge of a part or the fixed jaw of the vise when I drilled or milled a part I found that I was always off about .004.
Last test I did was yesterday. I ground and squared up a block of steel exactly 1" in width. Touched off on the back of the block and zeroed the DRO using the edge finder. came in exactly .500
I came down with a center drill and then drilled working my way up to 7/16" finished the hole with a 1/2" dia. end mill to eliminate any drill walk.
I measured the hole, it was off center by .0004.
So, I called Acu Rite. Talked to a tech and explained the situation. He asked me if I checked the run out on the probe tip. I hadn't so I did. The run out on the probe shank in my mill was about .0001, the run out of the probe tip was .0035. I thought OK, there's the problem.
Called the tech back and he said to loosen the 4 set screws on the top of the probe and tap the body around until I get zero run out at the tip.
I set the probe up in my grinder work head with a 4 jaw chuck so I could dial the shank in to zero run out. Once I did that I tapped the body around until I had zero run out on the probe tip.
I locked the set screws, check the tip as I went along and then checked the shank again. Dead zero at both ends.
I put the edge finder back in the mill, checked the shank, no more than .0001 run out, checked the tip of the probe and found about .002 run out. What's going on??
Any ideas??
Indicated the shank to zero run out.
JL..................
Indicated and adjusted teh body until I got zero run out on the tip. Locked the set screw and double checked both ends.
Put it back in the mill, checked the shank, less than .0001 run out. Checked the tip and got about .0025 run out.
