I need to replace the regulator on my fathers gas grill. Not sure what the deal is with it but I've heard this complaint from several people. After being lit for a length of time the flame fades out to almost nothing. Takes for ever to cook anything too. So what I have to do is disconnect the regulator from the tank and open all the control valves for a minute or so. Then close them and hook the regulator up to the tank. Then the flame burns normal. After a few cook outs the flame starts to fade again. I never really paid any attention to the length of time it takes for this to happen but it's an ongoing problem and has been ever since he bought this thing.
So the other day, I took the regulator off, had enough. I guess all these newer grills have fixed regulators, no way to adjust the pressure like the older ones.
I guess by disconnection the regulator from the tank and opening the valves allows the spring / diaphragm to re-set itself??
I don't really know what the difference is between a regulator designed for any gas like acetylene vs one used for air or O2. The rubber maybe. I've had several apart over the years and they all look the same inside.
In the picture you can tell which one is from the grill, made by Global. The one on the left looks like it came off an old furnace from the 40's. made by Penn Controls Inc. Model 1001 type 931 if that tells you anything. Probably natural gas? Don't know what it's set at as far as pressure. I suppose it can't hurt to try it.
The adjustable blue on I believe is an air regulator since it's marked 250 psi max. that one is made by Alemite model 32330-3 which means nothing to me since I cant find any info on it.
They do sell adjustable regulators for gas grills and or propane heaters, maybe I should try one of those. I just don't want to buy any chinese junk and then have issues with it a few months later.
I don't really want to buy a good one at a welding supple store and pay $200 either.
Any ideas???
JL...................
Any ideas???
