Depending on the accuracy of your measurements, you will never have perfect right angles nor perfectly parallel sides. There is always some error. Even Jo blocks are sold with a list of their deviations from the nominal size.
All of our work is done to some tolerance. Parts just need to be good enough to work in their intended application. A gate latch on a cow pasture fence does not need +/-0.001" accuracy, +/-0.1" or even greater will probably do. It seems to me that his method very quickly gets you into the ball park. And yes, it IS limited by the accuracy of your machine and vise: it is depending on those accuracies. But from that point you can then work to whatever level of accuracy that is actually needed.
Anyway, it seems to be useful to me.
Originally posted by MikeL46
View Post
