A video of a Swiss man restoring an old ratcheting screwdriver.
Sgt Joe Friday, AKA Jack Webb, was also the investigator on the "copper clapper caper" case, as I recall. That famous case was discussed at length on the Johnny Carson show, you might recall.
Yes he has huge number followers, I think he is high on desire, low on years. Though....
not sure about you guys, but I would have wound that so spring out... and the stuck parts..back and forth, back and forth.... .has Always been my rule..
I hope my 110 Miller will be able to weld like that. .
Visit my website for FAQ, a list of my machines, my products and some project documentations:http://gtwr.de/Consider supporting me on Patreon:https://www.pat...
I could not resist either, very workmanlike restore, especially that he actually saved the original parts as much as possible. What kind of mill was that? Thanks for posting. Jim
A Deckel, I believe. The only one I've ever seen running.
Oregon, USA
...making a small ball on his mill with a boring head.
As an FYI, if you are not too fussed about the diameter of the ball you make, you can use any tool that is hollow and has internal cutting ability. Such tools include a hole saw and a Rotabroach cutter. If you wanted a really large diameter ball, an insert shell mill would do it (the diameter has to be big as the hollowness is small).
