I have a need to cut or break some 1/8" carbide into 1/4" long pieces. Is it just a matter of scoring and snapping it?
Cutting 1/8" round carbide blank
I would do it this way:
1 drill a 1/8" hole 1/4" deep in a bit of steel or brass bar.
2 put your carbide in a collet with about 5/16" sticking out in the lathe or mill.
3 use a cheap square or triangular diamond mini file to score it as it rotates slowly.
4 use the drilled bar to snap off the carbide.
This is not guaranteed to work perfectly as carbide is unpredictable, but its the best I could think of.
How "straight" do you want the edges to be? Essentially scoring it with the triangle diamond file sounds like it might work. But if it doesn't you may need something more like a small diamond cut off wheel in a Dremel or similar. And if you need enough of them it would be worth getting one of the very small cutoff saws and put in a diamond blade. Or rig up a holder for your Dremel to turn it into a temporary cutoff saw.
Many have warned of the carbide grinding dust though. Wear a good particulate mask. And keep the dust away from any machine tools.Chilliwack BC, Canada
- Likes 1
