SB 10k gearing
Hrmm -- my mistake. It turns out the 40-tooth gear replaces the stud gear when doing coarse threads. Otherwise everything else the same. Sorry about that.
Originally posted by Bented View PostNot original or "correct" sell it immediatley even if it works fine.
"Correct" and original parts are more important then function.You forgot the "sarcasm" tag (it doesn't carry very well over the internet)
Originally posted by mwill135 View PostThe large gear in the middle is 80 I believe and the larger of the two (engaged) gear on gear box is 56.
Theoretically you could put any gear in there and do a lot of math to get some really weird custom ratios and screw threads. The 40 and the 56 cover all the common threads listed on the box.Last edited by nickel-city-fab; 08-30-2020, 04:50 PM.
IIRC the middle gear should be 80 tooth and the gearbox gear should be 56 tooth.
Originally posted by Ringo View PostIs that by chance the 100/127 tooth metric transpose gears?
SB 10k gearing
My gearing seems to be working fine but I don’t think this is the original or correct gearing. Can anyone identify the replacement parts?You may only view thumbnails in this gallery. This gallery has 1 photos.1 PhotoTags: None
