South bend 10k taper attachment
  • #16
    Originally posted by Ed P View Post
    Ohio Mike:
    "If installing a factory SBL unit you need the cross slide screw too. The non-taper and taper equipped machines are different. Be sure and check the parts breakdown for the 10K."
    Yes. I have one set in a bag when using the other one. Gotta keep it just in case.. JR
    • #17
      I checked your reference and could only find the taper attachment for the 10" lathe, not the 10K. I believe the 10K does not require a different cross slide screw.
      Ed P
      Ohio Mike:
      For reference http://www.wswells.com/data/parts/parts_form_index.html
      Form 902D 9/10K Saddle Parts Diagram. Am I reading this wrong?
      Click image for larger version  Name:	SBL Form 902D 10K Saddle.JPG Views:	0 Size:	118.4 KB ID:	1897401
      Central Ohio, USA
      • #18
        Model A and B have power cross-feed, while Model C does not
        So the changes refer to bearings supporting the screw, not it's length
        I believe the only revision when you add a taper attachment is the nut
        Rich
        Green Bay, WI
        • #19
          Rich
          What? I thought we were talking about cross slides. I must have missed the boat again Not my first time off the rails/
          Think of a free wheeling cross slide.
          It needs to be open for a Taper cut. JR
