Lift for the milling vise.
  • Lift for the milling vise.
    Well, my back is kind of a mess, arthritis, bulging and blown disks, so I made a shelf and a swing arm to take the large milling vise on and off. Also makes it easy to set it down gently on the table. I think I am going to do the same thing on the other side for a rotary table.
    how did you do the hinges? steel on steel?
      Cool job but, I would ditch the hook/rope on the vise and make a dedicated bar to clamp with the hanging point at the center of gravity.
      Helder Ferreira
      Setubal, Portugal
        I drilled a 5/8 hole through the tubing and legs, and pressed in steel bushings, 5/8 od, 1/2 Id. The square tubing is 1/8" wall, so I pressed in a bushing that is the width of the tubing. It swings smoothly.
          That was my next project. The rope was just Cobbled together to see how it worked.
            A very good and simple solution to the problem. No unnecessary complications.
              Now just extend (and strengthen) the shelf to accomodate the other table jewellery - rotary tale, dividing head...
              Ian
              All of the gear, no idea...
                I like it!
                  Ian
                  Accessories that are used on the machine table are commonly referred to as "furniture", not jewellery.
                  -Doozer
                  DZER
                    Are you calling my zircon-encrusted dividing head a sofa?
                    Ian
                      Nice job. Improvements like that pay dividends every time you use it.
                        Looks great!
                        This winter I want to make something similar for the lathe chuck.
                          Nice Job on mini jib crane,you sure have your Frejoth looking great!
