Is this really an exotic fastener?
  • #16
    Who uses Phillips heads over Allen socket hex head???
    Such an inferior way to transmit torque.
    -D
    It all depends on what your doing. SHCS are fine but stand higher than PH screws. BHCS are closer to PH screws but the hex socket isn't as deep as the SHCS. If torque is an issue, you may strip out the hex.
    If I really have to torque down a PH screw I use an impact driver...... not an impact drill / screw driver...... I mean the ons you smack with a hammer. I have an old one made by Vessel that I used to remove the PH screws on my motorcycle. https://www.google.com/search?q=vess...w=1536&bih=700
    JL................
    • #17
      I didn't really intend to make this about my car projects, but thanks, Guys.
      Ed
      For just a little more, you can do it yourself!
      • #18
        JL................
        We are talking about flat head screws, right?
        Phillips drive verses internal hex drive, right?
        You are saying Phillips are better, but only if you use a impact driver ????
        Really?
        No one mentioned Socket Head or Button head.
        So??
        -D
        DZER
        • #19
          -D
          You were the one that mentioned PH. But that's OK, we talk about all kinds of stuff here.
          JL..............
          • #20
            Originally posted by ed_h View Post
            Today, for a pretty routine job, I needed some 5/16-24 x 3/4" flat head Phillips screws.
            Ed
            Who mentioned Phillips ?????????
            Not I.
            -Doozer
            DZER
            • #21
              Bah, blame the British, those bar$tards.
              Super cool that you finished the TR6 Ed, I was following that build some years ago but forgot to go back to it. My Dad had one of those many moons ago and got a kick out of reading your restoration.
              • #22
                Just use a 1/4-28 and some JB Weld... works good enough for a Turnip.
                • #23
                  "Exotic Fasteners! $5 a show! Private shows! 24 hrs!"
                  Oh, Fasteners! I thought you said something else....
                  • #24
                    Originally posted by MattiJ View Post
                    Any UNF thread with philips head is probably not so common?
                    Actually the thread pitch has little to do with it. The diameter is more important -- it is very uncommon to find a Philips head on anything larger than small machine screws, Certainly I've never seen a Philips head on anything larger than 1/4".
                    Historical tidbit: The Philips head was originally sold to Cadillac car company to fasten their interior trim back in the 1920's. It was sold as a way to speed up production as demand increased, and not for any real quality. Source: (a very good book) https://www.amazon.com/One-Good-Turn...dp_ob_title_bk
                    • #25
                      I think these screws that hold the field cores in older starters and generators are 3/8".
                      I had read or heard that one of the original features of the Philips drive is that the driver would cam out before it could apply enough torque to break the fastener.
                      Ed
                      • #26
                        ...I had read or heard that one of the original features of the Philips drive is that the driver would cam out before it could apply enough torque to break the fastener.
                        Ed
                        In my opinion (?) Phillips heads work great for WOOD screws, but I find their use offensive on MACHINE screws.
                        That starter design is 100 years old. For real.
                        In shop manuals for starter work, it shows the starter fixed in an arbor press
                        with the ram applying pressure to a Phillips bit being turned by a wrench.
                        More evidence of a glaring mis-application of a fastener drive system.
                        -Doozer
                        DZER
                        • #27
                          r
                          They're the poor cousin of Robertson head wood screws.
                          About the only thing I'd say works well with a Phillips head is drywall screws
                          • #28
                            Wood/drywall screws. Same thing really.
                            I agree.
                            DZER
                            • #29
                              -Doozer
                              AMEN and amen! I could see Philips being OK for things like machinery tags, electrical parts, trim pieces etc. but *not* for anything critical to functionality. The pole shoes in my big welder are held in with 3/8-16 hex head bolts. Think about how much shear stress they are experiencing at a radius of 6" (12" dia generator) with 35 ft-lbs going thru the armature at 2400 RPM's... times whatever the magnetic strength is in there...
                              • #30
                                -Doozer
                                Yes, the use of large Phillips screws in that place was common, but a royal pain in the rear. Here's my implementation :
