It's ... yellow ... how do I mill it?
  • #16
    Originally posted by 754 View Post
    Try milling it and see. . Start out slow. .. the usual methods.. and then report back.
    Seriously, What else can you do ????????
    I was thinking the same thing.
    How do you know if tea is too hot to drink ?
    Sip it very slow and see.
    What else can be said unless you have access to a lab !?!!!
    -D
    DZER
    • #17
      Originally posted by Dan_the_Chemist View Post
      What is the appropriate arbor for that head? They don't say in the listing.
      How big is the spindle hole in your machine ?
      -D
      DZER
      • #18
        I would use carbide, its only metal, but I never had much bother wilh bits of titanium and inconel either.
        • #19
          High positive rake inserts such as the type you would use for Aluminum would be the way to go, IMHO. For plain brass you can use HSS just fine with the edges blunted off so it doesn't grab.
          • #20
            If it is to be a sword then it will have a pointy end so try a hacksaw to shape that bit. Blade is pretty cheap as a sacrificial try out.
            • #21
              954 aluminum bronze machines easily with hss or carbide tooling, beware the chips however.
              Fixture it up and machine at will, Whoever told you that it is a difficult material to machine is wrong. https://morganbronze.com/wp-content/...num_bronze.pdf
              I make these bearings from 954 often and have never had a tool failure, as mentioned be wary of the chips as they come off small, hot and sharp, I would recommend an enclosure and flood coolant for chip control.
              • #22
                Originally posted by CPeter View Post
                Where is "over here" and do you have a link to it?
                Peter
                Oops, my location isn't shown on this forum. Here is the Yew Ess Ay.. *Clicky on a users name to see their profile. Sorry but it's not sold in New hampsha.
                Only kidding, here's the hint but Ima gonna make you work for it. Copy paste the item description from his ebay link into your ebay search blank. You'll get a dozen sellers for it ranging from $10 and up. To the head you have to attach it to an arbor stud. Straight shank, R8, cat 30-40 etc.depending on what you have.
                • #23
                  If we were not here... you probably would have tried cutting it by now , hopefully start out slow..
                  the problem I see here is after what has been put on here, you actually might be afraid of cutting it now, due to a few comments..
                  Trust me, it won't machine itself.. give it a try.. might be easy. .
                  • #24
                    -D
                    Bridgeport ... R8
                    • #25
                      Did you see the other thread about "What holds you back?" I gotta spend a few hours with a shovel and find the bench in the shop first...
                      However, after seeing all the warnings about needing sharp tools lest it work harden, I ordered a few new end mills in various flavors. They will be here next week, so that gives me all weekend to procrastinate about cleaning the shop.
                      • #26
                        Specification:
                        Material:High carbon steel
                        Model:BAP 400R-80-27-6F
                        Insert Model:APMT1604PDER
                        Cutter:90°
                        Wrench:T15
                        Clamp screw M4X9
                        Size 50x80mm/2*3 inch
                        Suitable For:Roughing, finishing, mining and processing,cut processing tank, stepped surface machining.
                        Fit for FMB 27 arbor tool holder
                        I would say look for their "FMB 27 arbor tool holder"
                        in the R-8 configuration. That is all the information
                        that I see there.
                        --D
                        DZER
