Knurl on a mill?
  • Knurl on a mill?
    I’m thinking of trying to knurl an edge of an al part on my Bridgeport using lathe tooling. I have a share knurl tool that has a ~3/4 slot w/2 set screws
    thinking I’ll mount it to a bar in both quill and knurl on x axis.
    .200 wide. Use knee to feed in
    am I nuts!
    I did it on my Excello. Mounted the knurling tool in the vise and the part on a partially threaded shaft and that in the quill. And it worked!
      I have used cut knurling tool even on crappy drill press
        Internal knurling, fixing a loose bushing in a transmission tail housing. Click image for larger version
          No reason it couldnt work, after all a lathe is just a mill that someone knocked over during shipping
            Originally posted by no704 View Post
            ..... I have a share knurl tool that has a ~3/4 slot w/2 set screws
            What is a share knurl tool? Is that a typo?
            Lynn (Huntsville, AL)
              Reckon he meant "spare" knurling tool
              Frank Ford
              HomeShopTech
                Took me a second to see what you were doing - very cool! Have to remember that process..
                  Some clever methods, I now have something new to commit to memory, just in case.
                    Ok, that makes sense. I was thinking maybe "sharp," but "spare" seems more reasonable.
                        Ya have to zoom in a bit to see. It did work.
