How does one mill a 60" radius without a really huge rotary table?
  • #16
    Originally posted by Dan_the_Chemist View Post
    What you have labeled as 2.00 is 15.00 long, and what you have as 0.5 is 2.00 wide, and 0.5 thickness is in the axis away from you.
    So it is just a segment of a ring. What are the tolerances?
    • #17
      I did not remember seeing the tolerance for this small 60in disc.
      It really is difficult to turn that.
      I cant see a work around. JR
      Edit: I can turn a 60 inch round if needed. Seven inch thick ans 72 inches is my local.
      If you need bigger blanks let me know. 4200psi small banking presses. Oh? Hydro presses? hahaa JR
      • #18
        He says 60.00" and 62.00", so I assume the radius has to be correct to within 0.005". That's a lot to ask for with wooden jigs. Sounds like a part for a CNC shop to make.
        • #19
          Jeez do you guys even Read the simple solutions on here ? Or are you unable to absorb a simple technical discussion ?
          don't like a wood jig for 2 hrs use ? Fine build it out of metal..
          ? Tolerances ? .l sounds to me the radius will likely be set with a measuring tape.... how's that for setting tight tolerance ?
          GEEZ...just make 17 dollar wood pivot, you could be done already. . Just rough the blank on a band saw first..
          Make CHIPS... not Looooooooòoonnnnnnnnnnnnnnnnngggggggggggggg forum THREADS.......
          • #20
            Sounds a lot like a 2” bar run through some bending rolls to me
            But then we don’t know it’s actual end use (unless I missed that)
            Just south of Sudspumpwater UK
            • #21
              Yeah , cus like big rolls are easier to find than a few pieces of wood and a mill or a table saw.
              it could probably be done with a skilsaw and wood swing bracket.. or a router on a string, or bar..
              make chips, not long forum threads.l
              • #22
                It never ceases to amaze me how many people jump in to "answer" a question that haven't, either read the question or don't understand the terminology used.
                ...lew...
                • #23
                  Maybe you could figure out a way to set the radius from the spindle center to the riser center and swing the head around ?
                  • #24
                    I'm getting the impression that the phrasing of the problem (especially significant digits) makes reading/understanding it literally would be a waste of time.
                    ...lew...
                    • #25
                      . As I said earlier there are many ways to make arcs in a conventional mill. Such work was done long before CNC and putting Holes on
                      the end of the work piece allows the part to move ( as shown by Jerry ) in some complicated configurations .
                      Here is a sketch for another method that can be very accurate in arc generation. The colored link pivots on the mill quill and the rigid extension which is fastened
                      to the mill table . This setup makes errors almost impossible as the link could have a turnbuckle to make arc length adjustments
                      Skilled machinists would use depth mikes , exact chord length and balls (with trig) to determine accuracy of the arc.
                      In this method, both X and Y handles are turned to follow the curve exactly .
                      For example, if you move the X table , it will lock until Y handle moves .001 , so both are coordinated
                      Hope this helps.
                      Have seen other being used in job shops, but it gets complicated ( Cam Work)
                      Rich
Name:	Mill Setup JPEG.JPG
                      Green Bay, WI
                      • #26
                        Guys it's 60 inch radius ... not 16 inches... that 5 FEET for those that can't do Math in their head...
                        • #27
                          Maybe I'm under complicating it, but couldn't one lay it out with a large beam compass, rough in the bandsaw, sand close and finish with a file? That would be my approach most likely, but maybe that's why I don't have the job haha.
                          • #28
                            How would you produce the wooden pattern =/-.002?
                            Same problem as making the part. Just producing the layout lines is half the battle.
                            • #29
                              Originally posted by Galaxie View Post
                              Sounds like a good part to have laser cut (or water jet)
                              Does that imply a numerical control on the laser/waterjet? The OP mentioned WITHOUT CNC! This could be best sumerized as "farm it out" but where is the pleasure in that?
                              • #30
                                It's a 120 inch round Ten feet. Even big for a vertical lathe.
