Well, the CNC mill works!
  • Well, the CNC mill works!
    I need to practice using ball mills in Fusion360, so disregard the oval. This was just a quick test. The square clocks in at .500", the circle is 1.000" in both X and Y, depending how I hold the calipers. I'm ecstatic, just wish the mill was 3x larger now
    The heavy duty base, R8 spindle, and the 3 phase motor make this Taig an entirely different mill. The TTS tooling with height offsets in the tool library is the single biggest thing I ever wanted.
    Well, my tool touch off plate isn't working, that's easy to fix.
    GWizard will calculate the cusp or scallop height for you or you can model it in Fusion 360 in order to get a better finish with a ball endmill.
      Well done ! Lots of custom RC airplane parts on the way !
        Congratulations!
