Could I get a little CAD help, pretty please?
  • #16
    Here's screen shots, I made DXF's of both, PM me your email so I can send you the DXF's.
    • #17
      It's worth noting, I did this with the EAA $36 a year Solidworks.
      The subscribed version I have of Fusion360 refused to make drawings of the IGS files, says they contained no sketches, and not solid bodies. Solidworks didn't seem to care.
      • #18
        Deleted due to brain phart on orig. post!
        • #19
          About the same amount of time to do it in Fusion 360
          This is just the headstock:
          • #20
            You'll have to tell me how you did it
            • #21
              I have to ask... are those actual geometry files, or just sheet views? There is a huge difference.
              • #22
                If you zoom way in on the .dxf are there 7.2 gigabazzillion tiny line segments & microscopic points all over the drawing & then when you get all those deleted you find out that the main vectors are of square a tiny bit and the drawing is scaled up by 3.997654:1? I think there was raster/vector conversion going on or some such sorcery.
                • #23
                  In Fusion 360, you make a 'Drawing' of the model, then save that as a dxf. (This capability is being removed from the free version soon, much to the irritation of a lot of users.) You can also export a dxf from a sketch which requires projecting the geometry to the sketch.
                  • #24
                    Tried it, wouldn't let me. You must of used the other file format.
                    • #25
                      I scaled it up 4 to 1, these are sheet views. But should suffice for a parts locator.
                      • #26
                        In CB I just imported the STP of the spindle body (head stock), selected all the surfaces, and moved them to a hidden layer. Actual workable geometry of the surface edges remained visible. That's how I got the 3D line drawing shown in post #10. In VC I can select any part to export by itself.
                        There are what I believe are little indescrepancies in the original 3D model. They may be deliberate or they may be incidental.
                        • #27
                          It's hidden in the PDF Output menu.
