Could I get a little CAD help, pretty please?
Deleted due to brain phart on orig. post!Last edited by DICKEYBIRD; 09-26-2020, 04:45 PM.Milton
I have to ask... are those actual geometry files, or just sheet views? There is a huge difference.*** I always wanted a welding stinger that looked like the north end of a south bound chicken. Often my welds look like somebody pointed the wrong end of a chicken at the joint and squeezed until something came out. Might as well look the part.
If you zoom way in on the .dxf are there 7.2 gigabazzillion tiny line segments & microscopic points all over the drawing & then when you get all those deleted you find out that the main vectors are of square a tiny bit and the drawing is scaled up by 3.997654:1? I think there was raster/vector conversion going on or some such sorcery.Milton
You'll have to tell me how you did it
In Fusion 360, you make a 'Drawing' of the model, then save that as a dxf. (This capability is being removed from the free version soon, much to the irritation of a lot of users.) You can also export a dxf from a sketch which requires projecting the geometry to the sketch.
Originally posted by DICKEYBIRD View PostIf you zoom way in on the .dxf are there 7.2 gigabazzillion tiny line segments & microscopic points all over the drawing & then when you get all those deleted you find out that the main vectors are of square a tiny bit and the drawing is scaled up by 3.997654:1? I think there was raster/vector conversion going on or some such sorcery.
In CB I just imported the STP of the spindle body (head stock), selected all the surfaces, and moved them to a hidden layer. Actual workable geometry of the surface edges remained visible. That's how I got the 3D line drawing shown in post #10. In VC I can select any part to export by itself.
There are what I believe are little indescrepancies in the original 3D model. They may be deliberate or they may be incidental.Last edited by Bob La Londe; 09-26-2020, 10:25 PM.*** I always wanted a welding stinger that looked like the north end of a south bound chicken. Often my welds look like somebody pointed the wrong end of a chicken at the joint and squeezed until something came out. Might as well look the part.
