I have a mountain bike fork that has a steering tube that is short by 20mm. So I plan to lathe up a stepped tube, which I will shrink fit and Loctite into the existing tube. The OD is approx 1.13in and ID is approx 0.96in. The existing material is Aluminum, probably 6061. I plan on using the same.
For a tight shrink fit with this diameter, how much oversize should make my extension tube?
thanks!
thanks!
