Thank you all again for your help. The link provided by Harold Mulder is most helpful as it has silhouettes of spur gears in several DPs in both 14 1/2 and 20 degree PAs. I have an old Boston gear catalog with similar silhouettes but it omits the 24 DP which is what I need to cut. I've been able to verify the DP mathematically and more or less assumed the gear to be 14 1/2 degree PA because the machine using it is an older machine, however it's better to verify it before wasting time making the wrong part as has been mentioned here previously. I believe I can compare the broken gear I have to the silhouettes on the linked part and get some assurance of the PA.
My initial post made an assumption that if one were to have a set of Acme thread pitch gauges and happened to find one that fit a particular DP gear that the gauge would represent a rack of that DP with a 14 1/2 degree PA so that if the remaining teeth on a broken gear gear were to be able to run on the gauge smoothly with no visible clearance between the gauge and the tooth forms one might be certain that the PA is indeed 14/1/2 degree PA. If a 20 degree Pa gear were run on the same gauge it would seem that there would be clearance where the angles were not the same. Perhaps my thinking is flawed in this matter, however the suggestions above should help me verify what I am working with.
