I have an old 5hp minibike with a torque converter that all of the sudden started leaking air slowly from the rear tire. I pulled it off and checked and it's a tubeless tire and it has a bead leak. My thought is to put a tube in it but I can't get the bead broke loose. I even made an attachment for my arbor press and tried with that but it seems to be glued on. I am guessing that someone used inflate a spare or some other type of sealant in it.
I also took it to a mower shop and all they did was dent the rim with a hammer. Took it to a motorcycle shop and no joy there either. The tire has a really soft side wall and the motorcycle guy said they usually leave a pound or two of air in them to keep the side wall from collapsing but it didn't work for him this time.
Anybody got any other ideas short of throwing it in a fire and burning it off?
