OT: Medical Question on "Jumpy" Legs
  • OT: Medical Question on "Jumpy" Legs
    This may be the most Off Topic question ever posted here, but there is so much knowledge in this group that I felt I had to ask.
    My wife, who is in her mid 70s, has had an increasingly bad problem with her legs when she tries to sleep. Her legs become nervous and "jumpy". She can not sleep for more than a couple of hours without interruption. Then she must get up and walk around for a period of time before trying to get back to sleep. Our doctor has prescribed a medication to help, but she does not like the possible side effects.
    I would think that at least some of our members or their spouses would have this problem. So I am wondering what can be suggested to allow her to have an uninterrupted night of sleep. Any and all suggestions would be greatly appreciated.
    Some reports show good results from using C.B.D. for restless leg syndrome.
    Beaver County Alberta Canada
      Is it RLS or PLMD or ??
      What tests were taken?
      Too much caffeine? Low Iron levels?
        Has she tried the prescribed meds and does not like the side effects she gets? Or, has she read the info and doesn't want to experience the "possible" side effects? Not everyone gets all or any of the "possibles."
          An older friend of mine had the same problem. He went to a chiropractor and that helped him quite a bit.
          JL...........
            drink enough water, take good vitamins, eat less of what she eats most, including drinks such as tea if she drinks a lot of that.
              My wife had that. Caffeine in her evening tea was causing it. The caffeine didn't interfere with her sleep, but it did give her jumpy legs. She switched to a no caffeine tea in the evening and the problem went away.
              Design engineer
              Barrie, Ontario, Canada
                Paul.
                I get restless legs a bit , but not to the extent your wife does. Mainly just involuntary twitching when I'm trying to get to sleep. I have found that these help me. Not sure if they will be available where you are though
                https://schuesslertissuesalts.com.au...-tissue-salts/
                regards Peter
                  Does she drink diet cola? A friend of mine had restless leg syndrome and found that the aspertame in diet soda was causing it. Once he stopped drinking it his problems went away. I think caffeine has a similar effect.
                    I have one of those “Chi” leg shaker machines.
                    When I was working at the refinery I drank a lot of coffee each shift. I would get restless legs fairly often and using the machine before bed really helped.
                    Some units are pretty expensive, but ours was about $130 and has multiple speeds and 3 time ranges.
                    It’s supposed to help circulation too.
                    Illigitimi non Carborundum 😎
                      Hi,
                      There are several medications that can be prescribed for restless leg. But your wife may wish to have a sleep study done to get a better handle on all the issues that could be going along with the leg issues. I was prescribed gabapentin and an iron supplement along with a c-pap machine. Who knew that I could sleep more than a couple hours a night.
                      Poor sleep is not good for long term health.
                        I've had that problem occasionally, and found that taking an anti-histamine and/or a muscle relaxant such as diazepam or lorazepam have helped. Applying electrical stimulation via a TENS unit may also be effective. I found a fairly comprehensive list of suggestions:
                        https://www.healthline.com/health/re...her-treatments
                        USA Maryland 21030
                          She is afraid of a prescription medication. I wouldn't even mention that.
                          I have wondered about a glass of wine before bed time. But I doubt that she would agree to even that.
                            Caffine? I don't think so. She has one cup of coffee a day and often that is decalf.
                            Low iron? That could be. She was told to reduce her iron intake and she could be overdoing it. I am going to look into that.
                              I have that problem when napping in My recliner, hands move also. Solution..... move the recliner so Your feet are flat on the floor with a little weight on Them. Hands, just tuck Them along inside by My hips and all is good. Don't need much pressure.
                              mark costello-Low speed steel
