Parts for the conversion to EPI DIC showed up today. Good news is 3 of the 4 objectives I have work with the Komarski prisms in the nosepiece, I will need to find a 100x objective for the last turret position, tried the 60x I have but it does not work in DIC with that prism. Also the lamphouse is intended for a 12v, 50w lamps instead of the usual 6v, 20W lamp so I picked up an adjustable 3-12v, 5 amp power supply off amazon. Once I have that ill post some pics of the results.
