Can anyone ID this Doall
  • Can anyone ID this Doall
    Looking at a Doall for a freind it’s a 18” 3 wheel model cast iron frame only thing on saw says Doall Contour Saw,band wheels are 12” dia Click image for larger version
ID:	1907981 Click image for larger version
    https://www.doallsaws.com
    Could contact them.
    Beaver County Alberta Canada
      That's a JD or JXD model I believe, hard to tell which without seeing it in person. It's got one of the better welders on it. Usually a tag on the back of the arm with model & serial.
        I haven’t seen it in person yet,sounds like a few coats of paint have covered ID plates.Can’t find any info on those models you mentioned. Thanks
          Thanks wierd I did find some instructions info but no good images.
