I made this arbor to go on a 5/16 motor shaft, for a wheel with a 1/2 hole:
I used a piece of 1" mysterium in a 4-jaw, more or less centered,
-drilled a hole 1/64 shy of 5/16 (drill chuck in tailstock),
-used an adjustable reamer to open it to fit the shaft closely (a thou or 2 under 5/16), (reamer held in tailstock chuck & probably 4 passes or so to remove .015)
-turned the shaft to 1/2" & parted off (it was threaded with a die later).
Once the raw stock was chucked, it was not moved.
With it on the motor I was getting a lot of vibration, so I measured the concentricity on the lathe. The shaft has .006 TIR relative to the bore.
What happened?
What happened?
