Our biggest press in the fitting shop when I worked was very similar in design, but 25 tonne capacity. The lifting was achieved by a concentric pneumatic piston. You fully extended the ram and then put a collar on it with chains which slotted into the sides of the table. We had a 3/4" thick flame cut table about 3 x 2 foot fixed on it. It was not designed for punching work.
Finally got a decent hydraulic press
My old Wilson 75 Ton is a lot older than these, not as pretty, but plenty of power. Just messing around with it one day, I pushed a 1/2" steel ball thru a 1/2" steel plate. Only took 20 tons of push to do it. Mine was made during WW II , don't remember the date.
I remember trying to get some parts for it about 15 years ago, the Wilson press company was going thru one of its bankruptcies. Glad to see they are back in business.
Sarge41
Nice press and 75ton is not "too big" especially if you get into any heavy equipment or farm repair work. We have 50 and 75 ton Dake presses at work and I am drawing up a 150 ton in my spare time. On the one hand 75tons of force is a lot, but on the other, it's amazing how many times it isn't enough.I just need one more tool,just one!
That's an excellent press. I have a much older 60 ton unit with the cast iron pump and reservoir on the site. For those the pump packing can be purchased from McMaster Carr. Wonderful presses, I've only pushed mine a bit over 30 ton so far. Be careful, if you do the math your press can easily exceed the yield strength of the stuff you are putting in it.Mike
Central Ohio, USA
Originally posted by wierdscience View PostNice press and 75ton is not "too big" especially if you get into any heavy equipment or farm repair work. We have 50 and 75 ton Dake presses at work and I am drawing up a 150 ton in my spare time. On the one hand 75tons of force is a lot, but on the other, it's amazing how many times it isn't enough.
Doozer,
What is the hand wheel on the right side in the pictures for? The ram looks fixed from the picture so I can't see it moving the ram left or right, so I can't figure out what that side load assembly is for?
maybe you can enlighten us?
Curious minds need to know !
TX
Mr fixit for the family
Chris
I bet that thing would have happily squashed tubing for me when I was doing the ends of conduit for a frame. (Still have other jobs for the tool I made). I've been looking for one, even 20 ton, but have not liked the pricing.
That frame I have springs a bit at 3500 lb, the ram is supposed to do 4 tons.3751 6193 2700 3517
Originally posted by Doozer View PostKR Wilsons are rack & pinion arbor presses and hydraulic presses,
all in one. Guys go gooo gooo over Dake presses, but they ain't shlt.
-Doozer
Central Ohio, USA
