Anyone who does not get the difference between ground and neutral should not be doing electrical work.
What is this motor tag telling me?
Originally posted by outlawspeeder View PostIn the States we have three wires. 2 lines and a ground. Line to Line is 220-240, Line to ground is 110-120.Last edited by old mart; 12-31-2020, 04:01 PM.
Originally posted by old mart View Post
Is that single phase or two phase? Or both? A clever system if you know what you are doing, but it must be prone for stupid people to either run things over or under the correct voltage.
There is no problem with running over or under the correct voltage because the outlets are very different for appliances with plugs. And industrial equipment is almost always the higher voltage and amperage. The 110v is normally only for ordinary household outlets and lighting.Last edited by nickel-city-fab; 12-31-2020, 04:30 PM.25 miles north of Buffalo NY, USA
Despite quibbles by some, it is solidly single phase. If the two 120V lines were at 90 degrees phase angle instead of 180, it would indeed be classical 2 phase. But they are not. Too bad, since then we could all have 3 phase.
A mentioned, there are plug types for each, and they are not possible to plug in accidentally, so unless one of the brainless uses the wrong receptacle when they (as they often do) wire a new outlet, all is well.4357 2773 5150 9120 9135 8645 1007 1190 2133 9120 5942
"There's no pleasing these serpents"......Lewis Carroll
- Likes 2
Originally posted by nickel-city-fab View Post
Its basically single phase. Sometimes called "split phase" because electrically it looks like a coil tapped in the center. The center is the neutral, each "leg" is (nominal) 110v. Looking on a 'scope, each 110v leg is 1/2 of a full sine wave -- It just gets cut off flat in the middle, or "zero" point. Use the two outside legs to get the full 220v sine wave. Use one leg or the other with the neutral in the center to get the 110v.
No, AC is coming out of the wall. In the US the common wall outlet voltage is 120 volts AC in reference to Neutral. As stated above there are 3 POWER wires, 2 hot and 1 neutral and 1 earth safety ground. This is created by having a 240 volt ac transformer secondary with a center tap. The center tap is the neutral and also earth at the service entrance to the building/home. This is the ONLY place it is legal/allowed/mandated to join the neutral and earth ground together. The difference between neutral and ground it technical only. The neutral is designed to carry the current of the 120 volt AC loads back to the transformer. It is therefore considered a "current carrying conductor". The earth ground wire is for safety only and ONLY carries current if there is a safety fault in proper installations. So to answer your question, with the neutral as a reference the wall outlet is 120 volts AC 60 Hertz Rms sine wave. Now for our 240 volt AC appliances, heaters and single phase machines we simply use the two hot wires without the neutral. plus the earth safety ground This gives us 240 volt AC 60 Hertz Rms sine wave to use for higher voltage equipment. The main reason for this is that we can get twice the power out of the same wire by doubling the voltage and keeping the current the same. This results in smaller wire size for the same load. I hope this clears this a bit 😊Robin
Happily working on my second millionGave up on the first
- Likes 1
Originally posted by dian View Post
" each 110v leg is 1/2 of a full sine wave ": now you got me confused. is dc comming out of the wall?25 miles north of Buffalo NY, USA
Originally posted by old mart View PostI see, 180 degrees different. From what has been said, am I right in thinking that electrical plugs are not available for the public to buy in the USA?
You can buy whatever you want, no questions asked (unless your home burns down -- then they will be asking questions)Last edited by nickel-city-fab; 01-01-2021, 11:09 AM.25 miles north of Buffalo NY, USA
No, it is ordinary AC. The 110v is half of a wave, it could be either the bottom half, or the top half. If you are measuring a 220v line it will be the full wave. One easy way to think about it, is to imagine that the home is connected to a center-tapped transformer. The center tap is neutral, and the 2 outer legs each provide 110v but they are 180 degrees out of phase with each other, because the 110v legs are only providing half wave.
When looking at both, relative to the neutral, for one half-wave, wire "A" is a positive half sine wave, and wire "B" is a negative half sine wave. But they reverse for the next half wave, so that "A" is negative and "B" is positive.
If you look at just the two wires for 240V, you see an ordinary sine wave of 240V rms.
No net DC. You cannot get DC through a transformer, you have to "reset the core" so the input has to have as many volt-seconds negative as positive. (volt-seconds are the product of the voltage times the length of time it is applied)4357 2773 5150 9120 9135 8645 1007 1190 2133 9120 5942
- Likes 1
The 120V legs each provide a ful sine wave when looked at separately, it is just 120V rms.
No net DC. You cannot get DC through a transformer, you have to "reset the core" so the input has to have as many volt-seconds negative as positive. (volt-seconds are the product of the voltage times the length of time it is applied)25 miles north of Buffalo NY, USA
