And I have to say that I'm not impressed at all by the workmanship or the finish it leaves.
They must have ripped through those slots as fast as the cutter could move through it. Never even bothered to deburr the edges. The cutting edges are finished the same burrs and snags.
I did a couple test cuts with it.
The chamfer cut is left all scored with radial lines and the edges of each side of the chamfer are left with burrs. It doesn't leave a smooth finish, in fact it more or less plows through the material leaving windrow burrs on each side. I could do 100 times better with a regular late tool bit.
It's supposed to chamfer down to 1/4" dia stock but won't go much below 5/16". When I tried to chamfer 1/4" it cut more or less of a step on the edge, all burred.
Maybe I got a bad one or should try a different brand. I really didn't expect anything this bad. I thought it would be finished as nice as all my counter sinks are.
JL...................
