Originally posted by JoeLee
View Post
Got My Outside Chamfer Tool Today
I don't think a tool like this is easy to cut nicely with.
In a regular internal countersink, all the forces tend to center the tool in the cut; in this kind, any slight imbalance will want to throw it off-center, and mess things up. That will lead to chatter, especially if the teeth are all evenly spaced.
When you get chatter like the big piece , try turning machine off and as it coasts down, try cleaning bad part off, oil helps.
while cutting if it starts try peck feeding..like in harder momentarily then quick back off.. before harmonics can set off the vibrating.
my hunch is the good multi flute cuicutters ke Severance, have one or more flutes space at at different division, for better cutting. . I e a 6 flute won't all be 6 degrees apart.
Originally posted by 754 View PostWhen you get chatter like the big piece , try turning machine off and as it coasts down, try cleaning bad part off, oil helps.
JL.....................
That tool is simply a POS. The basic design may be OK, but it was very poorly made and that shows in the work done with it. McMaster, among others, has tools of this design and they are probably a lot better quality.
Some time back I needed to make several dozen aluminum pegs for a couple of racks to hang things in our laundry room. I choose 1/4" aluminum for the material and wanted the ends to look professional. That meant that I needed to face the ends and then put a nice chamfer on them. I purchased and used this tool for the chamfers and it worked perfectly.
It works on diameters from under 1/4" up to well over 1" and does both inside and outside chamfers. It did a great job and I have used it many times since. I highly recommend it. You can get one at various web sources. (I am not necessarily recommending any of these sources. They can be found many places.)
https://smile.amazon.com/TIPU-Inner-...xpY2s9dHJ1ZQ==
https://www.walmart.com/ip/Portable-...cc39e99892cb69
I also needed to face those 1/4" aluminum pins before cutting the chamfer on them. It would have taken a lot of time to chuck each one individually in the lathe or in a mill vise so I opted to make a one size, facing tool with a end cutting milling cutter and a scrap of steel.
I simply chucked it in a hand held drill and stuck the saw cut, aluminum blanks in the end. A few seconds and the end was perfectly flat. Notice the generous sized, cross drilled hole to allow chips to just fall out. It was well worth the small amount of time needed to construct it.
A similar tool could be made for one size, outside edge chamfering with a carbide insert. The trick with it is the single size design; that prevents any chattering.
With these two tools I was able to finish both ends of over three dozen pins in just a few minutes.
- 1 like
Originally posted by Paul Alciatore View PostThat tool is simply a POS. The basic design may be OK, but it was very poorly made and that shows in the work done with it. McMaster, among others, has tools of this design and they are probably a lot better quality.
I have one of those big plastic housed ID / OD chamfer tools like the blue one you show, only mine is red and carries the Rigid brand name and covers the same size tubing. It's OK for copper tube, breaks the inside edge left from a tubing cutter and cleans up any burrs on the OD, doesn't leave a pretty finish but who cares...... the end will be inside a female fitting and soldered.
The endmill thing is pretty clever. Nice job.
JL.............
I like the looks of this design (pipe reamer):
https://www.amazon.com/RIDGID-29983-...891729&sr=8-94
Originally posted by Joel View PostI like the looks of this design (pipe reamer):
https://www.amazon.com/RIDGID-29983-...891729&sr=8-9412" x 35" Logan 2557V lathe
Index "Super 55" mill
18" Vectrax vertical bandsaw
24" State disc sander
