I forgot to ask, is the chuck 6" or 160mm diameter? Is there any makers name on it?
3 Jaw Chuck Issues
The chuck measures 160 mm outside diameter. After a bit of Googling, I decided that I would grease it, so I greased the gear side and the scroll side with heavy duty grease. With a 1" diameter hardened and ground shaft clamped in the full length of the chuck jaws, I can slide a 0.0015" shim about 0.100" in from the face of the jaws. However, the jaws have about a 0.060" chamfer on the inside end of the jaws, so that test for "bell mouth" is rather inconclusive. The jaws are marked with two parallel lines looking kike a capital H with no cross bar, and a round smaller circle where the cross bar would normally go. This "logo" is inset in a round circle about 5/8" diameter on the face of the chuck.Brian Rupnow
Design engineer
Barrie, Ontario, Canada
I could get a 160mm Chinese made chuck in the UK for about £100 or less. I actually have two, both bought privately for quite a bit less in unused condition. They are not the same as the jaws differ in size, one being the standard Chinese and the other a copy of Bison dimensions. The rear mount screws are in a similar position to yours, but I cannot measure the pcd as the museum is closed during lockdown.
If the chuck is bell-mouthed enough to matter, you will normally see a trapezoidal wear on the jaw faces. However, that may not be the case with yours, or it may be hard to see. Best to do the regular check and see.
Also, see if the jaws are at all loose, they should normally be snug on their slides. Otherwise they may tip a bit, with the exact same result.
From your results, it seems as if those may not be your problem. Which leaves a mystery.
2801 3147 6749 8779 4900 4900 4900
It's just a box of rain, I don't know who put it there.
Originally posted by brian Rupnow View PostThe chuck measures 160 mm outside diameter. After a bit of Googling, I decided that I would grease it, so I greased the gear side and the scroll side with heavy duty grease. With a 1" diameter hardened and ground shaft clamped in the full length of the chuck jaws, I can slide a 0.0015" shim about 0.100" in from the face of the jaws. However, the jaws have about a 0.060" chamfer on the inside end of the jaws, so that test for "bell mouth" is rather inconclusive. The jaws are marked with two parallel lines looking kike a capital H with no cross bar, and a round smaller circle where the cross bar would normally go. This "logo" is inset in a round circle about 5/8" diameter on the face of the chuck.
- 1 like
like a mullet, grease at the back (pinion side) and oil at the front (scroll side). Grease in the scroll will trap swarf and grit, whereas oil is less likely to do so. Just stand to one side or put a bag over the chuck when you spin it up for the first time or you'll get a line of oil up your shirt.
- 1 like
It appears you got the lathe back from repairs at Concord. What turned out to be the problem with it? You said "electrical" in a earlier post.
Glad to hear the spindle runout is far better than you originally measured. This begs the question, did you re-measure the runout at the chuck again using the more suitable indicator? If so, what did you use for a test bar?
I am guessing that the chuck teardown at this point is just for routine maintenance, not due to a remaining runout problem, pending clarifications.
I am still chasing chuck runout. I have carefully checked the spindle with the chuck removed, and on both the faces and diameters and inside diameter available to be checked, there is extremely little runout, less than .001". Any of the diameters or faces that mate with the chuck show little or no runout. The spindle bearings have been tightened to specs given in the lathe manual. If I chuck a piece of ground and polished 1" round-stock in the lathe, I am still measuring 0.003" runout on the material. One thing I have noticed. When I bought the lathe new, the chuck would slide off the spindle nose with no problem when the chuck was unbolted from the spindle. Now it doesn't. I have to run the chuck jaws out enough that I can whack them with a soft faced hammer on the back side to get the chuck freed up enough to remove. This tells me that something has changed. Now I will do a very close inspection of the inside diameter of the back recess in the chuck which the spindle nose fits into, to see if there is any swarf embedded in that surface.
Design engineer
On my lathe the fit between the chuck and the spindle is not that great so when I put the chuck on I snug up the mounting bolts then put a new end mill in the chuck backwards to check the runout.
I few taps with a dead blow hammer brings it as close as it can get, then I tighten up the bolts.Larry - west coast of Canada
