Whats is It Tool? Old fashioned digital indicators.
Tags: None
Why do they have to belong to anything? Why can't they just be indicators?
Your photo hosting sucks. I click on the cursor that indicates it will magnify them and I get a smaller version. Clicking on that does nothing. What the heck??? I wanted to read the brand name.Paul A.
They are meant to be used on comparator stands. Digital and analog displays.
Originally posted by Paul Alciatore View PostYour photo hosting sucks. I click on the cursor that indicates it will magnify them and I get a smaller version. Clicking on that does nothing. What the heck??? I wanted to read the brand name.
Originally posted by Paul Alciatore View PostWhy do they have to belong to anything? Why can't they just be indicators?
- 1 like
Perhaps some of your software is really what "sucks".3751 6193 2700 3517
I have a couple of those and they're nice indicators. They use a special battery that's expensive if ordered from Federal, but you can get replacements from one of the electronic supply houses.
The display is electronic but with sort of a hybrid display. There's a zero setting and a digital display of the actual +- amount. Also, as you approach zero, there sort of a sweeping bar of graphic display to show how you're approaching the zero point or past it. Mine I think is metric meaning I'm measuring to .00004", close enough for who it's for..
Before I logged on, clicking on the picture gave just a tiny image, but having logged on, the picture is a usable 8" x 6", and then to 15 1/2" x 12" when I clicked on it on my 27" screen.
I would like to see what the indicators look like when switched on. I wonder whether any usable alternative battery could be used in them?
Federal is a quality manufacturer, most of the air gauging at work was their make.Last edited by old mart; 11-08-2020, 12:21 PM.
The black faces makes me think that it's got an LED display. Or possibly the blue display that was some other format and which was used on some of the calculators at the same time as LED's and prior to the shift to LCD.Chilliwack BC, Canada
I forget what the battery actually cost and it's been several years but something like $40 from Federal and $15 from Mouser. Don't quote me on that.
And I stand corrected that one of mine actually reads in inches but he last digit is just zero or five, IIRC the metric one actually shows the last digit so it would be finer grained by a few millionths FWIW.
The display is LCD to do the simulated dial indicator.
You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo.
I think the applications engineer I talked to sent me a .pdf of the manual which I should have somewhere if needed. I can't remember what all the other pushbuttons on the bottom do besides the big zero set so should probably review that myself..
That sort of indicator is intended for very fast checking of large batches, the excellent visibility allows instant reading within the set tolerances.
Am I right in thinking that most of the buttons can only be pressed with a ball point pen? If so, that would prevent accidental changes to the settings.Last edited by old mart; 11-08-2020, 02:13 PM.
- 1 like
Originally posted by old mart View PostThat sort of indicator is intended for very fast checking of large batches, the excellent visibility allows instant reading within the set tolerances.
Interestingly there's no of/off switch. When the plunger is either fully extended or fully depressed it goes into standby mode and shows just a minus (or maybe a plus) sign to show that it's still alive..
USA Maryland 21030
My cost? Zip/
My complain factor. Same
I always say blame Geo....
Hahaaaaa....
JR
And oops. Operator error. Too fast to click.
If you slow down the big fat pics I take will be threr.
