I recently bought a used Powermatic 143 bandsaw so I'd have a 14" bandsaw able to go slowly enough for cutting steel. It's had a fairly tough life and I'm probably the 5th or 6th owner judging from the multiple paint jobs. The PO did a nice job adding Carter blade guides and it came with many blades and so I'm happy with the purchase.
I would like to fix a few of the problems. One is that the blade tension indicator is wonked up - I think someone thought that it was supposed to be a support and welded things up. I ordered a new one and will try to clean things up but would like someone to take a couple of good pictures of that area. Mine is a newer model that has the 2 collars. I think the bracket that holds the pointer should be below the lower collar (bearing?) and floating. Here's a shot of that assembly on mine:
(Odd, had to upload as a link didn't work)
The second problem is a little harder to fix. The table is well adjusted for a 90 deg cut and that's 95% of the use right there. But when I rotated the table a little I noticed a lot of fore/aft movement. Looked and one trunnion was bend, likely in a fall. Rebent it and it's better, but in fixing that I found that the trunnion frame on the saw had been broken and rewelded but not straight. I *could* fix that but am hoping to find someone parting out a 143 who doesn't also need the trunnion frame, or even a commercial outfit parting out a 143. New trunnions are not available but can be easily made. Pointers?
