Originally posted by Doozer
View Post
OT - Products for the gullible
Endorsed by an angry Asian guy!http://pauleschoen.com/pix/PM08_P76_P54.png
USA Maryland 21030
Originally posted by Arcane View PostWhen I was a Lineman on a Transmission crew the odd time we would work in the substation outside the QE generating plant. The voltage from the generators was stepped up to 72, 138 and 230 KV in the substation with the 230KV being in it's own little area. I could work under the 72 and 138 KV bus bars ok but if I went under the 230KV bus bars, in just seconds I would get a mild headache. Leave and the headache disappeared too. I did some experimenting with back and forth and it would happen every time. What was perplexing was I wouldn't get a headache when I was doing hot work up a tower on the 230KV lines. The only reason for that that I could figure out was the tower lines had lower amperage on them than the bus bars did. Distance away was approximately the same for each.
If you work from a hot bucket, you are at no volts from the wire, and a long way from ground, same result.
The tower is indeed grounded, but with you working from it, it partly shields you from both the direct field from wire to tower, and the field from wire to earth.
The busbars are closer to the earth, and the volts per meter is proportionately higher. More current was passing through you, and evidently you are sensitive to that.. You might not have had the same result (nor have gotten anything done) if you were laying on the ground under the busbars, which is a bit like you being up on the tower.Last edited by J Tiers; 11-11-2020, 11:47 PM.3751 6193 2700 3517
Originally posted by Doozer View PostMost of the Edge Technology products are for the gullible.
-Doozer
I thought one of our Benefactors supplies this tool.
Ok. Lessons.
Do not Piss on yer Own Lawn. Got it. Sweet.
JR
- 1 like
The higher current would have produced a much stronger magnetic field, so perhaps that was causing the discomfort. There is evidence that strong magnetic fields may have some effect on blood flow, so it's possible that the headaches could be due to this effect. MRI machines may produce a much stronger field, but AFAIK it is pulses of DC current, whereas the bus bars would be AC.
https://sciencebasedmedicine.org/mag...nd-blood-flow/
https://www.oatext.com/electromagnet....php#gsc.tab=0
USA Maryland 21030
The scary thing about the website is that they seem to be doing business and actually selling this garbage. Good luck to them I suppose, but I find it a shocking reflection on the intellect of the people who believe in it.
Having said that, I have some positive earth-energy focusing crystals that I'd be willing to sell. They have been proven to be effective (although I don't happen to have the source at hand)...
IanAll of the gear, no idea...
do a search for audiophool. "golden ears" over 50 can hear the improvement in sound from aluminum cones that support speaker wires so the vibration from foot traffic does not intrude into the music. gold plated $150 power outlets to improve the quality of the AC distributed over 150 miles of copper power lines.
Originally posted by JRouche View Post
Hang on a Second!
Ok. Lessons.
JR
That's why I bought 5 acres.
Don't like my opinion?
I got a Himalayan crystal salt lamp for you.
You can lick it or plug it in.
Or both at the same time.
-DoozerDZER
Hang on a Second!
Ok. Lessons.
JR
I'd rather see an ad for a blow-up doll or The Ronco Pocket Fisherman, than that crap.
Products for the gullibleLast edited by Mcgyver; 11-12-2020, 01:36 PM.in Toronto Ontario - where are you?
- 3 likes
